Engine Cooling problem
1996 Acura TL 6 cyl Two Wheel Drive Automatic 90.000 miles
HI, I NEED TO KNOW IF IS IT NORMAL WHEN I PUT THE HEAT MORNING THE TEMPERATURE JAUGE GO UP. IS IT NORMAL?
Monday, October 13th, 2008 AT 10:59 AM
MECHANIC
Could be the engine temperature gauge sending unit is out of calibration
Thursday, October 16th, 2008 AT 11:49 AM
GENIE5353
MEMBER
That happened to mine in the beginning leading to a new radiator and a head gasket job. Hope not for you. Good luck.
Saturday, February 27th, 2010 AT 11:52 PM
RYGALLANT555
MEMBER
I tried everything on mine. It will blow your head gasket if you don't get it checked. Probably the fan switch though. Don't take to long or you will spend 2k for a new motor like me. Thats a tuff swap
