1996 Acura TL engine overheat
NDIABDOUL
  • 1996 ACURA TL
  • 6 CYL
  • 168,000 MILES
I have a problem with my 1996 acura TL 3.2 this morning when I start the car the temperature gauge was up to "H" but sometimes is going to normal and go back to "H". I want to know what' wrong thanks !
Sunday, September 14th, 2008 AT 8:13 PM
KEVIN12881
  • 336 POSTS
Could be a nomber of things from sticking thermostat to water pump. For a detailed explanation go to chevy lumina and read the artical of a 96 lumina overheating, just posted today
Sunday, September 14th, 2008 AT 8:30 PM
KHLOW2008
  • 41,814 POSTS
Hi ndiabdoul,
I would suggest checking the radiator coolant level first. If the gauges movement is immediately after starting from cold, then it most probably is electrical, either a faulty sending unit, wire connections or a faulty gauge.
Monday, September 15th, 2008 AT 11:16 AM
