1991 Acura Legend Won't Crank
BUSHG2
I have a '91 Acura legend 4dr sedan, don't know the engine size, but i think its a V6. My problem is that it won't start I don't even hear a noise when I try to cranik it, I don't think its the battery b/c the lights are bright, but in lifting the hood I noticed that the cap for the oil was off and probably has been that way since my last oil change(which was over a month ago) I thought maybe due to the heat that it might jus need some oil. It was strange because my car had been working up to that point fine, it cranked with no problem on my way to work. I thought it might be the oil also b/c of the heat and in looking at the oil measuring stick it looked bone dry
Aug 8, 2007 at 9:13 AM
  • 75,988 POSTS
[quote:a3db32d488="bushg2"]I have a '91 Acura legend 4dr sedan, don't know the engine size, but i think its a V6. My problem is that it won't start I don't even hear a noise when I try to cranik it, I don't think its the battery b/c the lights are bright, but in lifting the hood I noticed that the cap for the oil was off and probably has been that way since my last oil change(which was over a month ago) I thought maybe due to the heat that it might jus need some oil. It was strange because my car had been working up to that point fine, it cranked with no problem on my way to work. I thought it might be the oil also b/c of the heat and in looking at the oil measuring stick it looked bone dry[/quote:a3db32d488]
Maybe they forgot to put the oil plug back on or its leaking there better check
Probably the engine it seized-up. or you have a loose battery connection.
This is serious
Aug 8, 2007 at 10:08 AM
Suggested Repair
Check for a missing oil drain plug or oil leak and confirm the oil level. Also inspect the battery connections, and have the engine checked for seizure if it ran with little or no oil.
Conversation Summary
The owner of a 1991 Acura Legend says it suddenly will not crank and makes no noise, although the lights are bright. The oil filler cap was off and the dipstick looked dry. The expert suggests checking for a missing drain plug or leak, a possible seized engine from lack of oil, or a loose battery connection, and treats the problem as serious.
