1993 Acura Legend Steering Play
JOHN123
I have a 1993 acura legend 4door, 6cyl,.with about 80,000miles,.. I have 2 questions,. my first question is I have a lot of play on my steering wheel what causes that and what can I do to repair,.. my second question is that my seat belts lock up,. only in the front seats,. what caused that and is it expensive?? thank you john
Oct 1, 2007 at 9:35 PM
BRUCE HUNT
  • 3,754 POSTS
On the seat belt if you are referring to the not rolling back in, etc I suggest taking the panel off and lubricating the system.
The steering can probably be tightened but that depends on where the play may be coming from. There could be play in the tie rods, this probably would show itself with tire wear. There could be loose connections on the steering wheel. I might suggest taking it to an alignment specialist for evaluation.
Oct 2, 2007 at 7:07 AM
Suggested Repair
If the front seat belts do not retract, remove the trim panel and lubricate the retractor mechanism. For steering-wheel play, have an alignment specialist check tie rods, steering-wheel connections, and related wear; tire wear may indicate tie-rod play.
Conversation Summary
The owner of a 1993 Acura Legend with about 80,000 miles asked about excessive steering-wheel play and front seat belts that lock up. The expert suggested lubricating the seat-belt mechanism after removing the panel if the belts do not retract, and having an alignment specialist evaluate possible tie-rod play or loose steering-wheel connections.
