2000 Acura Integra type-r transmission codes
RIDETHROUGHLIFE
  • 2000 ACURA INTEGRA
Transmission problem
2000 Acura Integra 4 cyl Front Wheel Drive 73000 miles
I just bought a new-to-me/used b18b1 engine, and the seller claims to have coupled it to a type-r transmission, how would I go about verifying this? He claims a type-r intake manifold as well.
Saturday, January 23rd, 2010 AT 2:55 AM
F4I_GUY
  • 3,302 POSTS
There is a serial number on the transmission. It'll be right on the front of the transmission. It'll say something like S80-A5228. If there is no serial # that means it has been pulled off and there is no real way of checking (short of removing an axle to check if it has an LSD differential).
I can tell you for a fact that it does not have a type-r intake manifold though, because they do not bolt up to b18b1 engines.
Sunday, January 24th, 2010 AT 12:29 AM
RIDETHROUGHLIFE
  • 13 POSTS
That helps a lot. I do have that number set on the car. Will it only have it if it is a Type-R or will it be there regardless?
Sunday, January 24th, 2010 AT 7:57 AM
