WELL THERE IS NO SUCH OF THING BUT IF U WANT TO TAKE A TRANS OUT U HAVE TO TAKE ALL BOLTS OFF THE TRANS THEN REMOVE THE STARTER MOTOR IF IS AUTO TRANS U HAVE TO TAKE THE FLYWHELL BOLT OFF AND REMOVE THE TRANS IF IS MANUAL SAME PRESIDURE BUT U HAVE TO BE CARE FULL WHIT THE CLUCH USE ALIMENT TOOL TO CENTER THE CLUCH. OK
GOOD LUCK
SPONSORED LINKS
Tuesday, June 10th, 2008 AT 7:52 AM
