1994 Acura Integra Recent transmission work
GIRLY
  • 1994 ACURA INTEGRA
  • 4 CYL
  • 138,000 MILES
My front passenger side tire will not move when I turn the wheel. Does this have anything to do with the recent transmission work I had done?
Saturday, August 8th, 2009 AT 12:45 AM
KHLOW2008
  • 41,814 POSTS
Hi girly,
Your question is a little confusing. Can you please elaborate?
Is the wheel stuck?
Is the vehicle on jack or on ground?
Sunday, August 9th, 2009 AT 9:15 AM
GIRLY
To elaborate. When I try to turn the steering wheel, the tire will not turn. Does this have something to do with the recent work I had done on my transmission. This was not a problem prior to the repair.
Tuesday, August 11th, 2009 AT 12:08 PM
KHLOW2008
  • 41,814 POSTS
The steering system is not directly related to the transmission but while doing the work, some of the linkages could have been disconnected and while reconnecting, they could have been improperly reinstalled causing the wheel not to turn.
A visual check would have to be made to verify what is causing the wheel not to turn. Part of the steering linkage is disconnected either due to a fault in parts or installation.
Tuesday, August 11th, 2009 AT 3:25 PM
GIRLY
Tuesday, August 11th, 2009 AT 3:45 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad to be of service.
Thank you for using 2Carpros
Tuesday, August 11th, 2009 AT 4:04 PM
