You will need to machine the v-tec head to accept the larger NON-VTEC dowell pins, you will need to thread and put a plug into the main oil gallery for the cylinder head, then run an external oil line from your oil pressure sensor into the back of the cylinder head (you will need to purchase $120 SS line plus fittings for this). Then you will need to do a v-tec timing belt AND water pump, ARP head studs, and you will need to convert to an obd1 ECU and get it tuned by a professional on a software such as neptune, hondata, etc.
I'm sure I am missing a few small pieces of info needed, but an ls-vtec just isn't a straight plug and play.
To do a proper compression test on these motors, unplug the ECM F/I fuse in the underhood fuse box (15A), remove all four spark plugs so that there is no extra resistance on the motor while cranking. First do a dry test (meaning no oil in the cylinder) right down your recording. Place a capful of oil into the cylinder and re-test. Record all your numbers and post them up for us. Also, hold the throttle down while compression testing.
SPONSORED LINKS
helpful?Yes
Tuesday, January 13th, 2009 AT 5:21 PM
