1991 Acura Integra fuel pump/filter replacement
1991 ACURA INTEGRA
100,000 MILES • 4 CYL • FWD • MANUAL
R.FAULKNER1984
My acura has been sitting for over a year now and I want to get it on the road again. I know that the fuel is basically all sludge now, and I know the fuel pump was the original reason for it breaking down. My question is how do I drain the tank and change the filter, and is there an easy access to the tank behind the back seat?
Feb 15, 2008 at 6:06 PM
2CARPRO JACK
  • 11,533 POSTS
To remove just the pump, the access plate is under the back seat bottom.To get the whole tank out you will neeed to lift and support the vehicle very high, the tank is in front of the rear wheels
Feb 16, 2008 at 12:15 AM
