Turns over means it isn't electrical, but performance.
Okay so fuel is out unless it is in combination with spark or compression cycles based on the ether....unless it is getting too much, but you would smell that.
On a hunch I want you to crank the engine over and decide if it is spinning over faster than normal. Make sure the battery is brought to full charge first. If so we may have a timing issue.
Jun 10, 2009 at 12:12 PM
