1996 Acura Integra cracked heads
1996 ACURA INTEGRA
AMBRIANNAXXXX
1996 Acura Integra
i had a cracked head, but it was fixed with blue devil crack seal and it worked, the car was running hot and now its not but my plugs got wet from the overheating and etc, but now the head is fixed but my plugs are still getting wet and my car wont crank, it turns over and cranks eventually after the car gets warm?
Jan 16, 2010 at 9:47 AM
If its coolant its still leaking-if the engine is warmed it will fire up eventually due to metal expansion sealing the leak area-
Get it block and pressure tested to find out where its leaking
Jan 16, 2010 at 9:52 AM
