HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Integra
Engine
Cylinder Head
Gasket
1987 Acura Integra head gasket
PATTI THARP
MEMBER
1987 ACURA INTEGRA
Engine Mechanical problem
1987 Acura Integra 4 cyl Two Wheel Drive Automatic
does the steel sleeves in the engine block go above the deck height is this normal or what should I do
Sunday, August 10th, 2008 AT 4:07 AM
KHLOW2008
MECHANIC
Hi Patti,
The engine must have overheated badly and you need to reface the block or replace it.
It must be level failing which the engine will have overheating/compression leakages soon.
Monday, August 11th, 2008 AT 8:32 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Content
1996 Acura Integra Cracked Heads
1996 Acura Integra I Had A Cracked Head, But It Was Fixed With Blue Devil Crack Seal And It Worked, The Car Was Running Hot And...
Asked by
ambriannaxxxx
1 ANSWER
1996
ACURA INTEGRA
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Cylinder Head Gasket Blown Symptoms
A head gasket failure must be caught early to help protect the engine from additional damage. Understanding and recognizing these symptoms will be beneficial to your ...
1994 Acura Integra B18b1 Cylinder Head
Engine Mechanical Problem 1994 Acura Integra 4 Cyl Two Wheel Drive Manual Okay I Got An B18b1 Cylinder Head That I Bought. Everything...
Asked by
ringeeleng
1994
ACURA INTEGRA
I Am Getting No Power To The Ecm.
All 4 Fuel Injectors Keep Pumping Gas And Flooding The Engine.
Asked by
Larry84
12 IMAGES
1998
ACURA INTEGRA
Crank Shaft Pulley Bolt/putting On New Timing Belt.
1990 Acura Integra Gs B18a1 Motor, Stuck On The Crank Shaft Pulley Bolt, Been Told To Feed A Cotton String Down One Of The Piston Holes To...
Asked by
Nate621
1 ANSWER
2 IMAGES
1990
ACURA INTEGRA
Integra 94 Ls Timing Belt?
Yesterday My Car's Idle Was Idling Kind Of Rough, I Thought Nothing Of It But Had A Little Bit Of Concern But I Had To Get To Work, So On...
Asked by
MisterDB8
1994
ACURA INTEGRA
VIEW MORE
Coolant Mixing With Engine Oil
Engine Oil Change and Filter Mercedes Benz
