1995 Acura Integra
A 95 acura intergra with over 160,000 miles. The radiator has been changed numerous of times and within the last two years the water pump, fans, timing belt. Things were running fine until the last couple of weeks where the car started overheating again. The thermostat was removed and a couple of days after this I had to get a new battery which I bought and replaced myself last night.
Now today when sitting in idle the car starts to heat up the gauge slowly moves all the way to the last line so I check the cooling fan which did not turn on. I turned off the car and turned the key in the ignition without starting the car then the cooling fan turns on, I started the car again and the cooling fan does not turn on, I turned on the air condition and then both fans came on.
What can be the problem and at this point is it worth fixing? If so will it be expensive?
Thank you so much for your advice its greatly appreciated!
SPONSORED LINKS
Thursday, October 8th, 2009 AT 2:10 PM
