1995 Acura Integra overheating
COOL123
  • 1995 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 102,000 MILES
I was recently driving and my car started smoking (white) on the right side. I added a 50/50 mix of coolant to the car. However, after about 10 minutes of driving the temperature rises and the white smoke starts coming from under the hood. Do you know what's wrong with it?
Wednesday, April 30th, 2008 AT 4:55 PM
  • 31,937 POSTS
Hi there,
You will have to get a pressure test done, this will locate any external coolant leaks, also have a head check done just in case you also have a head gasket issue as well, as white smoke from the exhaust is a good sign of this problem.
Mark (mhpautos)
Wednesday, April 30th, 2008 AT 5:09 PM
