1994 Acura Integra start
1994 ACURA INTEGRA
100,000 MILES • 4 CYL • 2WD • MANUAL
ALFOGLES
It was sitting for a while and i replaced the distributer with one from a junk yard and it started and ran for about 1 1/2min.s then stopped and now i cant even get a spark on the plugs. I have already cheked the coil, battery, fuses, wire, cap, and plugs. How do i know if i need to get a new distributar or if it might be caused from a ground wire ??
Jun 12, 2009 at 4:27 PM
F4I_GUY
  • 3,302 POSTS
Check all your fuses and proper power and grounds going to the harness connector.
Chances are though, you just have a junk distributor. Purchase a new one and it should be fine.
Jun 13, 2009 at 11:27 AM
