1994 Acura Integra oil disappearing?
1994 ACURA INTEGRA
175,000 MILES • 4 CYL • FWD • MANUAL
CBORDEN
  • 29 POSTS
ive had my integra for only a year and when my clutch blew out and i went out and just decided to check my oil and the dipstick comes out completely dry but when i change my oil i got the recommended amount in there and when i got my valve stem seals replaced the technician told me my exhaust side smelled alot like gas like it wasnt burnin it all off and on the front side of the engine some oil seems to be leaking oil front the head gasket area but ive also already replaced the head gasket another mechanic said it may be the fuel regulator is bad and is dumping too much fuel in and washing down the cylinder walls or i was thinkin the piston rings were bad or going bad any ideas?
Apr 30, 2010 at 12:45 PM
KHLOW2008
  • 41,814 POSTS
Hi cborden,
Thank you for the donation.
Honda engines would not have any problem with oil leaking from the head gasket. If it is from the front end, ie near the timing belt side, most likely source would be the camshaft seals or valve cover gasket near the camcarriers. During installation, sealant have to be applied at the corners of the valve cover gasket to prevent leaking.
For exhaust fumes to smell strongly of gas, there are many possible causes.
If the injectors are dumping in too much gas, the spark plugs would be sooty and you would have erratic idling issues. Starting would be affected as well.
A bad catalytic converter, O2 sensor, Throttle Position Sensor, clogged air filter, fuel pressure regulator ( this item seldom fails for Honda), clogged fuel return hoses are some of the possible items.
Piston rings can go bad at high mileages so is a possibility with your case but after replacement of the valve seals, do you still have oil consumption issues? Do you have a lot of grey exhaust smokes at high rpm?
If too much fuel is being dumped into the cylinders and cleaning up the piston rings, you would have compression and difficult or non starting issues.
Note : I have seen very few honda engines with problem on pistons rings.
Is the performance of the engine as good or better than replacement of the valve seals and head gasket?
Recheck the timing belt installation. A off time cog can cause erratic idling and strong exhaust fumes and performance issues.
Apr 30, 2010 at 4:04 PM
CBORDEN
  • 29 POSTS
the oil is leaking for the front end but not on the cam side its coming from where the head meets the cylinder head right where the head gasket is and im thinking when it was replaced maybe the head wasn`t torqued down enough
and my spark plugs were getting sooted up but someone told me thatr bosch wasnt good for honda so i changed them out for ngk
and wouldn`t a cat or bad o2 sensor throw off a check engine light?
cause i dont got one
and i havent noticed black smoke coming out the back but the back of my car has a black trail coming up it from the exhaust side
and recently the car seems to pause for a moment before it wants to start
and the performance seems the same after the seals were redone i just wanted to get em done cause the engine was old
and the car has been retimed about three times within the last few months
May 1, 2010 at 2:37 AM
KHLOW2008
  • 41,814 POSTS
The head gasket is the steel type and if it is not torqued correctly, the engine would be running badly.
At the front there are no oil pressurized passages but if the cam seals are leaking, the oil would drip down and out to the front.
A bad cat might not throw any codes and if fuel is being dumped through the cat, it would run red hot.
Was the ignition timing checked ?
The black trail indicates the cat is not working correctly.
May 1, 2010 at 3:21 AM
CBORDEN
  • 29 POSTS
what about when i go to check my oil the dipstip comes out dry?
May 1, 2010 at 4:42 AM
KHLOW2008
  • 41,814 POSTS
Does the exhaust emit grey smoke at initial start up, maybe a few nimutes after starting up?
Is the leak very bad?
How many miles have you driven the vehicle after oil replacement?
May 1, 2010 at 4:58 AM
CBORDEN
  • 29 POSTS
i havent really looked to see if the exhaust was emitting smoke and idk if the leak is bad but the oil slowly disappears i dont know what to do ive changed valve seals the pan gasket head gasket i dont even drive the car 3000 miles before oil replacement and it seems the oil is gone after a month and i dont race the car i try to take it slow cause i know the engine`s old and i dont need anymore problems i probably did oil change early last month and thats whats left and some sort of liquid is comin from the passenger side of the engine whats ignition timing? i have after market cam gears that i cannot get the specs on and could all the oil loss be from cam seals?
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01186_1.jpg
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01187_1.jpg
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01189_1.jpg
May 2, 2010 at 7:56 AM
KHLOW2008
  • 41,814 POSTS
Adjustable cam sprockets means the valve timing might not be accurate and that can cause the timing to be off and that can result in the incomplete combustion.
The liquid leaking from between the tran and engine area could be from the distributor or its O ring.
You might need a thicker grade oil if the one that you are using is being depleted too fast.
Ignition timing is the time the spark fires and is affected by the distributor position.
If the cam seals are not properly installed, it can leak quite badly. You would need to remove the valve and timing cover to have a visual inspection.
May 2, 2010 at 8:19 AM
CBORDEN
  • 29 POSTS
last time i got it timed the tech said everything was set to zero but since i cant get the spec cards to the gears theres no way to be certain that its 100 percent i would have to remove the distributor in order to replace the o ring? the oil im using is recommended for the engine what grade should i use? could the distributor be off and cause a premature or delayed spark to occur and result in these conditions how would i know if they were properly installed (cam seals)and how would i reinstall them properly i have new replacements (cam seals) i just figured the old ones were still good because there were no obvious sign of leaking there profusely
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01122_1.jpg
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01188_1.jpg
May 2, 2010 at 9:15 AM
KHLOW2008
  • 41,814 POSTS
You are right about the cam seals not leaking judging by the picture.
Ignition timing is adjusted by turning the distributor clockwise or anti clockwise. If the timing is too advanced or retarded, it can cause performance difference.
Yes, the distributor has to be removed to replace the O ring.
The recmmended oil is 10 W30. You can try 20/W50.
For the camshaft sprockets, they have to be adjusted to get the correct valve timing. Our database do not have the specifications for the valve timing.
May 2, 2010 at 10:26 AM
CBORDEN
  • 29 POSTS
i removed the distributor the o ring looks fine and it doesnt seem to be leaking any oil from that side
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01192_1.jpg
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01193_1.jpg
i was lookin at the seal behind the vtec and it doesnt look to be seated all the way but would this cause all the oil to disappear
https://images.2carpros.com/forum/automotive_pictures/522752_DSC01194_1.jpg
and doesnt 20w50 seem a little drastic? and i figured you didnt have the specs its just my luck but how would i correct it without buying new wheels i thought that the rotor on the distributor is supposed to be at the #1 plug while the gears should point straight up along with the crankshaft? the aftermarket gears are not adjusted and are still pointed at 0
May 2, 2010 at 10:40 AM
KHLOW2008
  • 41,814 POSTS
Is there any oil stains below the VTEC valve? The cam end cover would tend to leak as well. Unless leaking is noticed, if not it is not going to cause the oil to disappear.
No, 20/W50 is not really drastic. In fact for slightly temperate regions that is the recommended grade.
The distributor is only installed in one position but the tightening points are slotted so the distributor can be turned clockwise or anticlockwise to a certain degrees. A timing light is required to check the correct position.
May 3, 2010 at 1:53 AM
CBORDEN
  • 29 POSTS
i replaced all the gaskets when i replaced the head gasket
and imma have to check the vtec to rule that out
and how would i fix the distributor`s timing with the light exactly
May 3, 2010 at 5:40 AM
KHLOW2008
  • 41,814 POSTS
The timing mark is at the pulley.
With timing mark clipped to 1st cylinder spark plug wire, aim the mark at the pulley. You would notice the mark on the pulley. Match the center mark of the 3 close slots to get the correct ignition timing.
The VTEC valve tends to leak when the gasket hardensover time.
May 3, 2010 at 8:38 AM
CBORDEN
  • 29 POSTS
ok so possibly buy a new vtec gasket
but would that fix it because it doesnt seem that a small leak like that would make all my oil vanish after a month or so
and what if that doesnt correct the problem?
May 3, 2010 at 10:25 AM
KHLOW2008
  • 41,814 POSTS
The 3 conditions/areas that causes oil depletion are :
1. Oil leaks from seals, drain plug, oil filter or gaskets. Leak have to be substantial and easily visible to cause the condition.
2. Bad valve seals. Though they have been replaced, there is no guarantee that it could not be the cause. Quality of the seals and installation error can be a factor. For this condition, grey smoke would be emitted during abrupt revving of the engine if the exhaust valves are bad as the oil is being discharged directly into the exhaust system. For intake seals to be bad, the smoke emision would be at a lower rate as the oil is being burnt in the cylinders before being discharged.
3. Worn piston compression and/or oil rings. This would result in the high blow-by gases in the crank ventilation system and oil would be discharged to the air intake hose from the valve cover ventilation hose or the PCV valve into the intake manifold.
If it is only high blow-by, smoke emission would not be high as the oil is being mixed with the air to be burnt in the cylinders.
If it is the oil rings that are bad, smoke would be visible under high rpm loaded conditions.
If leaking is the only cause of the oil depleting, rectifying the leak would solve the problem. If you get under the vehicle, you would notice that the lower portion would be damp with oil dripping onto the floor after running the engine.
Whether replacing the VTEC gasket solves the problem or not would depend on whether it is the only cause.
May 4, 2010 at 4:13 AM
CBORDEN
  • 29 POSTS
im hoping its just a leak and that the vtec gasket is bad because oil is leaking from that side of the engine and i guess over a month of continuous leaking the oil could be all gone and im in the process of purchasing a timing gun to retime my engine
with your help and the help of a local technician i better understand how to retime the vehicle a lot better
and i just hope its not the rings or valve seals
first of all i just had the seals done and its a pain to do them
and piston ring jobs are expensive and it may be time to get the rings replaced but im just not financially ready to get that done yet
May 4, 2010 at 8:18 AM
CBORDEN
  • 29 POSTS
is it possible that not having any oil control orifices could cause any problems?
May 4, 2010 at 8:58 AM
KHLOW2008
  • 41,814 POSTS
It would cause oil pressure and/or noise problem but not depletion of oil.
May 4, 2010 at 9:06 AM
TENNHICKS
Have you noticed it smokeing when you first start it.It very well could be the valve seats need replaceing..
May 4, 2010 at 9:12 AM
CBORDEN
  • 29 POSTS
no i just checked yesterday but and there was no smoke but there was some liquid coming out the exhaust
May 5, 2010 at 2:52 AM
KHLOW2008
  • 41,814 POSTS
During initial starting and at idling condensation in the exhaust system would result in water being discharged from the exhaust and that is normal.
May 5, 2010 at 4:21 AM
CBORDEN
  • 29 POSTS
well actually i started the car and let it warm up before i even saw the liquid appear and it was at high rpms that the liquid was ejected i thought it may have been fuel from the timing being off and not burning it all off
and next payday ill be purchasing a new vtec gasket a timing light and doing an oil change and ill let you know how that turns out
i hope that it gets better most of all the oil stops leaking
but it doesnt make any sense that supposedly all the oil`s gone but the oil light doesnt come on
May 5, 2010 at 6:16 AM
KHLOW2008
  • 41,814 POSTS
If it is fuel being ejected, the cat converter would be running red hot. I believe that is condensation ( water ) being ejected.
Did you check if the oil light is working correctly? Even at very low oil level, the light might not come on or it would only flash intermittently.
May 5, 2010 at 6:26 AM
CBORDEN
  • 29 POSTS
well i didnt neccessarily check the light but when i turn the engine on w/o turning it on all the lights turn on and eventually all turn off so i just figured the light was working correctly
and i really didnt check to see if the cat was red or not but you may be right
and i know that the oil light prob works the same as the gas light
but the oil light has never came on during regular running
and when i dump the oil during the change like i said the right amount is in there but it kinda seems thinned out and smells alot like gasoline
May 5, 2010 at 6:38 AM
KHLOW2008
  • 41,814 POSTS
If the right amount of oil is inside, then the dipstick should be able to detect the level.
Gas in the oil means too much fuel is getting into the cylinders and getting past the rings but under such condition, there should be excessive smoke and the engine should be running erratically at idle due it running excessively rich and the sparks plugs would be fouled.
May 5, 2010 at 6:54 AM
CBORDEN
  • 29 POSTS
my bad i meant that theres still oil in there only about 2 qts at the most but it does seem thinned out and my last set of spark plugs were fouled bad after only a dew weeks after buying them then someone told me that brand doesnt work very well with tuners so i upgraded to ngk iridium and the car seemed to work fine for a while but now it seems the car is sluggish now and delays before takeoff
i havent checked the sparkplugs yet again but i would doubt it if those ones are fouled up now too
and sometimes at idle the car`s rpms would go way up close to 3gs sometimes then back to idle and back and forth
and i have seen smoke but its rare i though it had nothing to do with these problems i though i was because i was a really hot day or water had gotten on the enigne
May 5, 2010 at 7:07 AM
CBORDEN
  • 29 POSTS
i meant i wouldnt doubt it if the spark plugs were already fouled again
May 5, 2010 at 7:08 AM
KHLOW2008
  • 41,814 POSTS
I would suggest this. Get the leaking repaired and then perform a tune up with checking the ignition timing.
After that retest vehicle and monitor the engine oil condition.
After some running, recheck the oil level again and also the spark plug conditions.
May 6, 2010 at 3:30 AM
CBORDEN
  • 29 POSTS
yea im goin to get the leak fixed hopefully with the vtec gasket imma retime it change the oil and spark plugs
im just upset cause not too long ago i replaced the plugs and wires
May 6, 2010 at 4:25 AM
KHLOW2008
  • 41,814 POSTS
Keep me updated on the progress and if you require additional information, let me know.
Have a nice day.
May 6, 2010 at 8:54 AM
CBORDEN
  • 29 POSTS
alright i just got done retiming my car earlier today and while i was marking the pulley with the chalk and noticed that the splash guard had oil residue on it and it looks like the oil pan gasket is messed up again and i already replaced it not even six months ago and im thinkin possibly the gasket behind the pulley might be bad or something cause there seems to be grease clumped up on everything around the pulley whats your idea(s) on this cause im upset that i seem to fix one thing and another thing goes out
https://images.2carpros.com/forum/automotive_pictures/522752_downsize_1.jpg
https://images.2carpros.com/forum/automotive_pictures/522752_downsize_1_1.jpg
and now that ive retimed my car the sputtering and misfiring has died down i had to adjust the timing closer to tdc because its was already perfectly timed on the red timing mark
May 22, 2010 at 5:30 PM
KHLOW2008
  • 41,814 POSTS
The grease seems to be from the inner CV joint. Check the boot for tears and the clips to ensure they are secure.
As to oil on the splash shield, the only way to find out is to clean the area and run the engine then check for the source of the leak.
Regarding the ignition timing, do you mean it does not run well when the timing is at the red mark? If yes, you need to recheck the cam timing again.
The rear cam might be out of time.
May 22, 2010 at 6:38 PM
CBORDEN
  • 29 POSTS
i just replaced that axle though why would it already be messed up?
and yea im about to change the oil so before i do that ill check were its coming form because i do not like changing that pan gasket its not hard its just messy
and i got the car as best timed as it can be because i have after market cam gears and i dont have the spec cards because they came on the car and the wheels are now discontinued so i cant locate them should i buy another set
and i replaced the vtec gasket and im glad i did because the old one was quite hard and broke apart while i was taking it off
and i fixed the cam seal also
May 23, 2010 at 8:46 AM
KHLOW2008
  • 41,814 POSTS
I do not have the specs for the valve timing so would not be able to help you on the timing.
If the axle is new, the grease could be there before the so clean them up and retest.
Axles sometimes do have the boot bands slightly out of specs so it they ae loose, grease would be silled out while running.
May 23, 2010 at 11:21 AM
CBORDEN
  • 29 POSTS
so should i buy new cam wheels or no?
and can i tighten up the clamps
or do i need to replace something?
May 24, 2010 at 2:10 AM
KHLOW2008
  • 41,814 POSTS
If the clamps are not sufficiently tight, retightening them would do.
As to the camsprockets, unless it is oem where it would be standard. Otherwise you would need the valve lift specs to adjust them. If not you would have to go by a trial and error whereby you mark the initial point and then you can try moving the cam position slightly forward or backwards.
Usually when adjustable cam sprockets are installed, they would tend to increasr the timing of the valve lift so you can try retarding the cam slightly. Remember to mark the initial piont correctly and to retard the valve lift, the cam sprocket must move forward slightly so that the camshaft would be slower than initial.
May 24, 2010 at 3:37 AM
CBORDEN
  • 29 POSTS
alright i dont understand why i changed the oil pan gasket for the third time and its sealed and everything and theres no visible signs of leaking ( no puddles under the vehicle or drip spots or anything) but i had it full yesterday and now its to half full,and i made sure i didnt over torque it,i just dont understand why and how the oil is dissappearing
its really frustrating me!
May 28, 2010 at 7:07 AM
KHLOW2008
  • 41,814 POSTS
When no oil leaks are present, the only way oil could be disappearing would be via :
1. Valve seals.
2. Piston oil rings.
3. Intake manifold via the PCV.
For any of the above conditions to occur, it would not use up half the oil on the dipstic mark, it should be almost 1 quart for that amount, unless the engine is smoking badly from the exhaust.
Top up the oil and check the oil under the same conditions, ie before start up every morning. After starting the oil level might be different as some oil could be trapped somewhere and not getting down to the sump fast enough.
May 29, 2010 at 1:54 AM
CBORDEN
  • 29 POSTS
the thing is i filled it up with whatever oil i had left which was just over a quart and then i checked it and the oil level was way above the top mark and one of my buddies told me that when i hit vtec a small puff of black smoke came out of my exhaust
could this be part of the oil dissappearing?
May 29, 2010 at 5:14 AM
KHLOW2008
  • 41,814 POSTS
If any oil is being burnt in the engine, the smoke should be grey and not black. Black smoke are from unburnt fuel rather than oil.
It needs to be smoking badly for the oil to be disappearing that fast. Remove the oil filler cap with engine idling anc check if the blowby gas is being pushed out with smoke.
May 29, 2010 at 6:49 AM
