1994 Acura Integra NEED HELP.
YANKEE18
  • 1994 ACURA INTEGRA
Engine Performance problem
1994 Acura Integra 4 cyl Front Wheel Drive Manual 112XXX miles
HELLO MY NAME IS YORDANKY AND THE REASON WHY IM DOING THIS IS BECAUSE MY INTEGRA WONT GO OVER 3500 RPM.I HAVE CHANGE FEW PARTS BUT IT STILL THE SAME.I CHANGE THE DISTRIBUTOR, MAP SENSOR, FUEL PUMP. THE CAR GETS STOCK THERE AND IT WONT PASS THE 3500RPM IN ANY GEAR.
Tuesday, July 21st, 2009 AT 11:54 AM
KHLOW2008
  • 41,814 POSTS
Hi YORDANKY,
Does engine rev higher than 3500 rpm when in neutral?
Does it get stopped by the rev limiter?
Did you test the TPS readings?
Did you retrieve for trouble codes?
Thursday, July 23rd, 2009 AT 10:39 AM
YANKEE18
Yes the car goes higher than 3500 rpm in neutral and it does stop by the rev limit.
Friday, July 24th, 2009 AT 6:58 PM
KHLOW2008
  • 41,814 POSTS
Is the MIL showing?
Was this the cause for replacing the items mentioned above?
What is the engine type?
Friday, July 24th, 2009 AT 8:19 PM
