1994 Acura Integra Lug Nuts
1994 ACURA INTEGRA
PIMPNUTZ
Tires and Wheels problem
1994 Acura Integra 4 cyl Front Wheel Drive Automatic
I have snapped two lug nuts on a 1994 Acura Integra. I have taken off the bracket for the calipor, as well as the calipor itself. I have also removed the center bolt for the axle. I am stuck at this point. How do I get the lug nuts out? Simply pushing them out to the back, is not possible, because the bolts hit part of the wheel assembly, and will not come out. Please help.
May 2, 2008 at 7:42 AM
THEBIGGMCDOG
  • 25 POSTS
u need press out the bearing out
May 26, 2008 at 11:47 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
You need a puller to get the hub flange loose enough to get the stud out.
You need to press the flange back before installation if not your wheel bearings will have too much free and give way prematurely.
May 27, 2008 at 8:50 AM
