HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Integra
Tires
Alignment
SPONSORED LINKS
1990 Acura Integra rear wheel alignment
MIKEW44452
MEMBER
1990 ACURA INTEGRA
1990 Acura Integra
I have a acura integra 1990 and the rear passenger wheel is tipped inward at the top and it is wearing the tires. Is there a way to correct this?
Friday, October 24th, 2008 AT 5:26 PM
KHLOW2008
MECHANIC
Hi mikew44452,
The rear cambers are out of specs and
1. Check the lower control arm bushes for wear and adjustment.
2. Check upper arm bushes for wear.
If both are ok, you need to readjust the camber by adding shims to the upper arm mounting area.
SPONSORED LINKS
Monday, October 27th, 2008 AT 2:29 AM
Please
login
or
register
to post a reply.
Related Alignment Content
1998 Acura Integra Buddyclub Camber Kit Legal On...
1998 Acura Integra 4 Cyl Two Wheel Drive Hi, I Got A New Front Rear Camber Kit. My Camber Kit Is A Buddyclub. I See On It (...
Asked by
bussie
1998
ACURA INTEGRA
1998 Acura Integra Skunk2 Pro Series Camber Kit...
Suspension Problem 1998 Acura Integra Manual Skunk2 Racing Adjustable Front Camber Kit (+/-5 Degrees) For Acura Integra 94-01 Fit...
Asked by
bussie
1998
ACURA INTEGRA
1992 Acura Integra Tire Camber
Suspension Problem 1992 Acura Integra 4 Cyl Front Wheel Drive Manual I Am Circle Track Racing A 92 Integra With The 1.8l Motor And...
Asked by
fishbait
1 ANSWER
1992
ACURA INTEGRA
Car Shakes Above Fifty Mph Even After Tire Balancing
I Noticed My Car Shook Pretty Hard Above Fifty Mph, So I Looked Up The Fix Online And Everyone Said To Get My Tires Balanced. So I Got Them...
Asked by
kaio
2000
ACURA INTEGRA
1994 Acura Integra Lug Nuts
Tires And Wheels Problem 1994 Acura Integra 4 Cyl Front Wheel Drive Automatic I Have Snapped Two Lug Nuts On A 1994 Acura Integra....
Asked by
pimpnutz
1994
ACURA INTEGRA
VIEW MORE
SPONSORED LINKS
Ball Joint
Ball Joint Replacement
Tie Rod End Replacement Mercedes Benz
Online car repair manuals
