1994 Acura Integra Brake Grinding
The grinding noise. Rotors were turned or replaced? Do you feel any movement in the steering wheel when the brakes are applied? What kind of pads were put on? I would check that the caliper in tight or secured well to the vehicle.
Suggested Repair
Reset the yellow maintenance light with the ignition off: hold the odometer reset button, turn the key to the position just before start, and keep holding until the light clears. For the front grinding while braking, confirm how the rotors and pads were serviced, check for steering-wheel movement under braking, and verify that the caliper is tight and securely mounted.
Conversation Summary
The owner of a 1994 Acura Integra with 320,000 km reports a low front grinding noise when braking after a left half-shaft CV boot, front rotors, and brakes were serviced, and also asks how to reset the yellow maintenance-required light. The expert explains the odometer-button reset procedure and asks whether the rotors were turned or replaced, whether the steering wheel moves during braking, and what pads were installed. The expert also recommends checking that the caliper is tight and well secured.
