Go to your hood, and pull the 15 amp fuse (ECM) and 7.5 amp fuse (radio ) out
leave the car sitting for 10 minutes with the fuses out, after 10 minutes replace the fuse.
Start your car and your check engine light will go off.
1) if it isnt a serious issue the CHECK ENGINE LIGHT WILL not go back on.
2)if the check engine lights goes back on instantly then you are definately gona want to go to autozone, checkers, advancedauto, to have 1 of the workers there can use the OBD and pull up the faulty code. Its 100% free of cost to you.
After obtaining a obd it will be alot easier for the rest of us to assist you.
If your check engine lights does not go back on again, then dont sweat it might of been something minor. But like I said if it is a problem that needs attention, the check engine light will go on even if the ECU/ECM has been resetted.
Sunday, June 6th, 2010 AT 6:41 PM
