My son has a 2001 Acura Integra and he has installed a Vibrant Exhaust system, Short Ram Air air intake with a K&N Filter and new Magna Flow Catalytic converter. Ever since he did all this the check engine light has been on, he has replaced the rear O2 sensor (as indicated by the engine codes). Now the engine codes for the check engine light indicates the problem is the catalytic converter. Having made all these exhaust changes has he changed the emission "mix"? Does the ECM chip need replacing or can this problem be fixed? He wants to sell the car and needs to get the light out, I would appreciate your comments thank you.
Steve Deninson
Steve Deninson
Sep 18, 2008 at 2:27 PM
