Best possible guess is that the car has fairly recently overheated causing the head gasket to fail. This was possibly caused by a crack in the head or a warpage of the head. You can take off the head and have it checked and planned at the auto parts shop. Put on a new gasket and things should be back to normal, however, I would be looking for a reason as to why the vehicle got hot. Ie crack in the radiator, leak in hose, bad thermostat, etc.
SPONSORED LINKS
Monday, January 28th, 2008 AT 2:53 PM
