Electrical problem
1990 Acura Integra 4 cyl Front Wheel Drive Manual 186k miles
I rebuit my 1990 Acura Integra. I put bigger cams, bored .30 over. Adjustabel cam gears, cold air intake etc. Everything is brand new in the motor. My problem is I'm throwing a code 4. Crankshaft Position Sensor. I have replaced the dist. with a new one and still throws a code 4. My buddy has the same b18a motor and took his dist. off and put it on my motor and still throws a code 4. I ran two jump wires from the sensor itself to the ecu and still throws a code. I have checked and also a mechanic has checked the wires from the dist. to the ecu and they all check out fine. Whats my problem??
Sep 8, 2008 at 9:17 AM
