1995 Acura Integra crankshaft
1995 ACURA INTEGRA
GRODGERS61
  • 10 POSTS
Engine Mechanical problem
1995 Acura Integra 4 cyl Front Wheel Drive Automatic
i'm working on a 1995 ls motor,
and the crank torque spec. were not in the book.
need to know torque on cap bolts, please and thks.
greg
May 17, 2010 at 5:22 AM
KHLOW2008
  • 41,814 POSTS
Hi grodgers61,
Here are the specs.
Main Bearing Cap Bolts
Non Vtec engine.
Tighten main bearing bolts in 2 stages. First tighten bolts to 22 ft. lbs. (30 N.m), then tighten to 58 ft. lbs. (73 N.m).
Vtec engine.
Tighten main bearing bolts in 2 stages. First tighten bolts to 22 ft. lbs. (30 N.m), then tighten bearing caps No. 1 and 5 to 56 ft. lbs. (73 N.m) and bearing caps No. 2, 3 and 4 to 49 ft. lbs. (64 N.m).
© 2008 Mitchell Repair Information Co., LLC.
May 17, 2010 at 6:16 AM
