1991 Acura Integra ECU says crank angle sensor, code 4
COLTANGMANG
Engine Performance problem
1991 Acura Integra 4 cyl Front Wheel Drive Manual
I have had a 91 acura integra 2 door ls for a month and a half now and it was running perfectly fine, then one day i was driving got out, got back in and started driving and i killed it, cant get it past 3000 RPM says its a crank angle sensor? I want to know how do i check the sensor and where is it located...? I really need help, any info is appreciated..
Nov 13, 2009 at 2:28 PM
KHLOW2008
  • 41,812 POSTS
Hi coltangmang,
The Crank Angle sensor is located inside the distributor and if it is bad, the distributor would have to be replaced.
You would need an ohmmeter to test the coil resistance of the CKP.
Nov 19, 2009 at 2:45 AM
