1989 Acura Integra
TRUCKIE503
  • 1989 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 136,000 MILES
How to remove and replace the altenator
Saturday, November 22nd, 2008 AT 12:02 PM
DAVE H
  • 13,384 POSTS
ALTERNATOR
Removal & Installation (Integra)
Disconnect negative battery cable. Raise and support vehicle. Remove front wheels. Remove left front axle shaft. See appropriate FWD AXLE SHAFTS article in DRIVE AXLES. Disconnect wiring harness connector and White wire from alternator.
Remove alternator belt. Remove lower mounting bolt, and swing alternator upward. Remove alternator mounting bracket. Remove alternator adjusting nut and upper through bolt. Remove alternator. To install, reverse removal procedure.
Sunday, November 23rd, 2008 AT 5:52 AM
