Air conditioner system
CAROL KLAMERUS
  • 13 POSTS
Wrenchtech, Sure seems they sell alot more PAG 100 around here & I was checking some prices at Autozone, they list some that must be gold! PAG 46 8 oz. For $56, 68. 75. & Even a 6 oz for $176! Unless these are strange typos. But did find some 8oz for $9-10. Though there was a charging one of 3oz for $7. So they come with or without UV dye & some come with ICE. Than the R134a most come 12 oz. Plain $10, with dye $20, with ICE $19. With stop leak $15-20. Do I want oil with dye & 134 with ice or sealant or just plain? Thanks.
Monday, June 13th, 2016 AT 5:20 PM
WRENCHTECH
  • 20,761 POSTS
Definitely no sealant
No ice
Dye is a good idea to help find any leaks later.
Monday, June 13th, 2016 AT 5:23 PM
CAROL KLAMERUS
  • 13 POSTS
You wonder why they sell all those options, just to make more money for stuff we don't need but people think they do?
Monday, June 13th, 2016 AT 5:25 PM
WRENCHTECH
  • 20,761 POSTS
If they can talk somebody into buying it, they will sell it. We're up to 3 pages on this now and you haven't even stated the job yet so I'm going to be away for a while.
Monday, June 13th, 2016 AT 5:29 PM
CAROL KLAMERUS
  • 13 POSTS
Hi Wrenchtech, so I worked on my project on Sat. Compressor came out easily, oil was clean in it, drier was clean also as well as the lines. Added oil to drier, & new orings to lines, compressor in. Than hooked up manifold gauges & vacuum pump, seemed to hold pressure like should, but when trying to charge, compressor would not kick in, even trying to bypass with drier switch & was not pulling in any refrigerant. After some time we looked at the manifold, some orings looked iffy but I think the real problem was the connectors to high & low side were not opening the schrader valves. We tried a can with a hose & it started filling up. After needing to visit a few Auto Zones finally got a decent manifold & restarted process. This time compressor kicked in quickly & got it charged up. (It amazes & saddens me that AZ is providing these tools for us to rent for FREE & people just abuse them although perhaps the workers also don't maintain the equip.) Anyway I do notice often when starting the AC a squeal for about 5-10 seconds. Don't want any issues with my new compressor. Wondering if it is my belt tensioner & need to replace that?
Tuesday, June 21st, 2016 AT 4:08 PM
WRENCHTECH
  • 20,761 POSTS
I don't have a picture of the belt system but I think it is a manual tensioner that is adjustable. It sound like the belt needs to be tightened a little.
Tuesday, June 21st, 2016 AT 4:14 PM
