1998 Nissan Frontier A/C only works on highest setting
1998 NISSAN FRONTIER
143,000 MILES • 4 CYL • 2WD • AUTOMATIC
WOLFMAN79
My A/C has been acting up like this for almost a year already. I had no intentions of fixing but the 104 degree weather in TX is starting to become unbearable.
I noticed too, that when I have it on the highest setting for awhile, maybe like 20 minutes, it stops blowing out cool air.
The only work I've done to it so far was replace the A/C relay with no luck on fixing the problem.
Any ideas why it's not working on the other settings?
Thanks for your help.
Aug 12, 2010 at 10:04 AM
Check and test the blower motor resistor
Aug 12, 2010 at 11:30 AM
WOLFMAN79
[quote:1a538c919d="rasmataz"]Check and test the blower motor resistor[/quote:1a538c919d]
Right after I posted this I was flipping through my automotive manual and checked the wiring schematic.
Took the blower motor resistor out and found that it was bad. Replaced it and the A/C works like a charm.
I'm still having issues with the loss of cooling after having it run a few minutes. I think I might have to recharge it. Any ideas?
Thanks for your quick response rasmataz!
Aug 12, 2010 at 12:46 PM
