A/C is not cold when idle
BAKHTIAR DUSKY
  • 96 POSTS
Today the A/C fan set was almost at minimum.
The A/C is working fine the car was idle for about 15 minutes.
Saturday, October 12th, 2019 AT 1:49 PM
  • 52,797 POSTS
You still have the same problem. It will be back and you will still have to do the repair we discussed. It cannot and will not fix itself.
Saturday, October 12th, 2019 AT 5:00 PM
BAKHTIAR DUSKY
  • 96 POSTS
Forget to tell you this : when I set AC to Max the Psi was about 50 when when the ac was on minimum the psi was 35 just to let you know.
Okay, thanks dude. I will check that and post the updates.
Sunday, October 13th, 2019 AT 12:44 AM
  • 52,797 POSTS
Sounds like a plan.
Sunday, October 13th, 2019 AT 4:45 AM
BAKHTIAR DUSKY
  • 96 POSTS
I meant its normal when the ac at max the psi 50 and if its min its about 35?
Sunday, October 13th, 2019 AT 7:05 AM
  • 52,797 POSTS
It should never change ever.
Sunday, October 13th, 2019 AT 7:08 AM
BAKHTIAR DUSKY
  • 96 POSTS
Oh, I see. Thanks for the info bro learned a lot from you.
Sunday, October 13th, 2019 AT 9:17 AM
BAKHTIAR DUSKY
  • 96 POSTS
Tested again. The Low and high Pressure at 2,000 rpm's after the leak the Low was 20 psi and the high was 125 psi.
Sunday, October 13th, 2019 AT 11:52 PM
  • 52,797 POSTS
Again, it does not matter. You have a bad expansion valve. It should never change pressure reading whether at idle, 2.000 RPM's or any other time.
Monday, October 14th, 2019 AT 3:32 AM
BAKHTIAR DUSKY
  • 96 POSTS
Okay, checked the pipe it is not leaking it is like an oil around it.
Monday, October 14th, 2019 AT 8:39 AM
  • 52,797 POSTS
Okay, you still need the valve.
Monday, October 14th, 2019 AT 9:36 AM
BAKHTIAR DUSKY
  • 96 POSTS
Noticed something else; when it blows a warm air I hear a weird noise sound near compressor under the hood.
Tuesday, October 15th, 2019 AT 4:57 AM
  • 52,797 POSTS
Can you upload a video of the noise to this post?
Tuesday, October 15th, 2019 AT 5:20 AM
BAKHTIAR DUSKY
  • 96 POSTS
I found a video with the same sound start from 44 seconds. That's hissing sound.
https://youtu.be/yrGuT_rjf68
I am not home right to make a video of my own if Its necessary i can make my own later. But it is the same sound.
Tuesday, October 15th, 2019 AT 7:52 AM
  • 52,797 POSTS
Okay, that noise is the compressor itself making some internal noises.
Looks like you need to add that to your list of needed parts.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Tuesday, October 15th, 2019 AT 8:02 AM
BAKHTIAR DUSKY
  • 96 POSTS
But do you think this issue caused the refrigerant to be leaking in the first place?
Tuesday, October 15th, 2019 AT 8:09 AM
  • 52,797 POSTS
No, it may have gone low in oil over time and this is the result. Hard to say without removing and disassembling the compressor for inspection.
Tuesday, October 15th, 2019 AT 8:17 AM
BAKHTIAR DUSKY
  • 96 POSTS
Oh I see, thanks.
Tuesday, October 15th, 2019 AT 8:18 AM
  • 52,797 POSTS
You are welcome.
Tuesday, October 15th, 2019 AT 8:22 AM
