AC not working
MERLIN2021
  • 17,250 POSTS
Check the low pressure switch, it's on the low pressure line, At compressor, If out of R134a, and compressor can run, switch is defective. This will overheat the compressor, no oil running through it!
https://www.2carpros.com/forum/automotive_pictures/62217_stratus_1.jpg
DIAGNOSIS AND TESTING - A/C EXPANSION VALVE The expansion valve is located on the engine side of the dash panel, near the right shock tower. The expansion valve can fail in three different positions (open, closed or restricted). In an Open Position: this will result in a noisy compressor or no cooling. The cause can be a broken spring, broken ball or excessive moisture in the A/C system. If the spring or ball are found to be defective, replace the expansion valve. If excessive moisture is found in the A/C system, recycle the refrigerant. In a Closed Position: There will be low suction pressure and no cooling. This may be caused by a failed power dome or excessive moisture in the A/C system. If the power dome on the expansion valve is found to be defective replace the expansion valve. If excessive moisture is found recycle the refrigerant. A Restricted Orifice: There will be low suction pressure and no cooling. This may be caused by debris in the refrigerant system. If debris is believed to be the cause, recycle the refrigerant and replace the expansion valve and receiver/drier.
Monday, January 13th, 2020 AT 1:25 PM (Merged)
BURNTTATERTOT
  • 2003 DODGE STRATUS
  • 6 CYL
  • FWD
  • 66,593 MILES
Heater doesn't blow hot air at an idle. Only when foot is on the gas and rpm about 1500 or higher. All vacum hoses are connected can't find and air leak anywhere. WHAT IS IT?
BLUELIGHTNIN6
  • 16,542 POSTS
Check coolant level first to ensure there is enough coolant in system.
Thanks for using 2carpros. Com!
SAPPHIRE0922
  • 2004 DODGE STRATUS
  • 6 CYL
  • 61,000 MILES
I have a 2004 Dodge Stratus R/Tl with about 61000 miles on it. I have not had any problems except that all of a sudden the air conditioner stopped working. It blows out hot air only. I have had two people look at and one work on it. The first guy said that there was a hole in either the refrigerant or liquid line and no freon and quoted me at about $900 to fix. The second guy ran the dye thru and said that he could not detect any holes at alll and that the pressure was where it should be. He put freon in it and checked it periodically throughout the day and the air got as low as 59 degrees. That lasted about 2 days and it started blowing out hot air again. Nobody seems to be able to find anything else wrong with it. What else could it be? Also, just this last day when I started my car in the morning it made a coughing sound when I started it but then was normal. The weather has gotten cooler as low as high 40s could this be the problem? Thanks!
Monday, January 13th, 2020 AT 1:27 PM (Merged)
  • 31,937 POSTS
HI there,
Thank you for the donation,
If the second mechanic could not find a leak, why did he have to re gas the system? Well I think that if the system was low and he could not see any evidence of a leak with the dye, there may be a small leak at the evaporator, (this is hidden under the dash and you can't see it) you may have to get an electronic gas sniffer test in the vent as if the evaporator is leaking this will pick up refrigerant in the vents, try this next.
Mark (mhpautos)
  • 109,867 POSTS
First, the person who said their was a leak and no Freon was in the system seems to be wrong. If the system was working for 2 days, there has to be freon. Could their be a leak? Yes, there could. If you have the vehicle at the shop, they should have a freon sensor that basically is like a dog sniffing out its prey. If freon is present (leak), the sensor indicates it. Also, that would tell the mechanic where the leak is located.
Has the person who had it working checked for leaks?
JULIE CRUM
  • 2.4L
  • 4 CYL
  • MANUAL
  • 187,000 MILES
I had cold air while driving on the interstate, but when you slow down or stop it blows heat. We bought an eighteen ounce can of refrigerant and put in it. Now when you check the pressure it is in the blue and says it is charged. But, now it only blows heat. There are no leaks, you can hear the compressor kick in and out and collateral is full. What do I do?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,330 POSTS
It sounds like you have a compressor going out, you will need to connect a gauge set to see both high and low side readings.
Here is a guide to help you get started:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
and
Please let us know what you find.
Cheers, Ken
