AC compressor clutch
132,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DKDODGE1516
  • 22 POSTS
I put Freon in my AC compressor it cycled a couple times and then just wouldn’t cycle anymore I’ve had it overcharged and took some of the pressure off and did it again and it cycled a few times and then wouldn’t cycle anymore. Is there some sen AC compressor clutching so that’s going bad or what do you think the problem is?
Jun 7, 2019 at 7:10 AM
Good afternoon,
You need to get a set of gauges and give me the high and low side readings of the system while running.
You can rent a set or buy a cheap set at Harbor Freight.
I need those readings to help you.
Jun 7, 2019 at 7:32 AM
