When did you add the oil? It should have been added before the Freon was installed.
Tuesday, June 19th, 2018 AT 4:33 PM
ZEMORZEMOR
MEMBER
I added the oil when I removed the compressor. I put six ounces I did not add anymore after that.
SPONSORED LINKS
Tuesday, June 19th, 2018 AT 4:37 PM
MECHANIC
Six ounces to where? The compressor or the Freon system?
Tuesday, June 19th, 2018 AT 4:39 PM
ZEMORZEMOR
MEMBER
The compressor.
Tuesday, June 19th, 2018 AT 5:04 PM
MECHANIC
Okay, good. I do not see any issue here at all.
As I stated way back, a little oil in the Freon system is normal.
SPONSORED LINKS
Tuesday, June 19th, 2018 AT 5:11 PM
ZEMORZEMOR
MEMBER
Can you tell me what pag oil 2000 Mazda protege 1.6 L manual takes. There was no Freon in it completely empty, however when I pulled vacuum waited thirty minutes no drops on vacuum. Checked shredder valve no leakage. Can you answer this question here or I need to asked another question? PT Cruiser is my significant others car. Mazda is mine.
