2001 Chrysler PT Cruiser engine is overheating when I flip on air conditioner
TONY B.2601
  • 2001 CHRYSLER PT CRUISER
Engine Cooling problem
2001 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic
OVER HEATS WHEN AC IS ON. CLEANED RADIATOR AND COND. COIL FAN WORKS CHANGED THERM. CHANGED TEMP SENDER TIRED OF CHRYSLER!
Saturday, August 15th, 2009 AT 11:21 AM
DOCFIXIT
  • 18,828 POSTS
Cooling fans have two speeds check dark green wire at fan motor for voltage. Then put AC on now check for voltage on yellow. If none then high speed relay faulty.
Saturday, August 15th, 2009 AT 11:42 AM
TONY B.2601
  • 5 POSTS
DUN THIS FAN IS WORKING ON BOTH SPEEDS.
Sunday, August 16th, 2009 AT 8:36 AM
