Code C0045 and C0561, ABS, track lights, all wheel drive off lights are on
  • 52,797 POSTS
Okay, did you check on the reading when spinning the wheels and check AC voltage?
Sunday, November 22nd, 2020 AT 8:43 AM
DRFIROJTADAVI
  • 33 POSTS
No sir, I will borrow the second jack to free both rear wheel.
Sunday, November 22nd, 2020 AT 8:58 AM
  • 52,797 POSTS
Okay, keep me updated.
Sunday, November 22nd, 2020 AT 9:04 AM
DRFIROJTADAVI
  • 33 POSTS
Your advice for wiggle test worked. I started from sensor to ABS module but no success. Then I inspect fuse box which wiggling, so I tightened connectors and fuse box. That might have been loosened while I had removed the upper intake manifold for that I have to clear the harness aside which going to PCM from fuse box above the manifold with tension wires. Any way now no ABS lights and no codes.
Tuesday, November 24th, 2020 AT 6:20 AM
  • 52,797 POSTS
Good find.
Glad it is fixed.
Tuesday, November 24th, 2020 AT 6:33 AM
