ABS light on
225,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
RANDY CARTER
Making a stop ABS and Parking brakes came on, no cruise control. steering tie rod were bad. change t rods, ABS come on with switch on. Parking brakes comes on goes out comes back on and beeps for ten seconds. Regular brakes are okay. ABS pump stays on.
Mar 20, 2019 at 8:41 PM
Good morning,
There are fault codes in the ABS system with the light. These codes will give us a direction to go for a diagnostic.
https://www.2carpros.com/articles/brake-system-warning-light-on
You can have the codes read for free at a parts store. Once you know the codes let me know so we can narrow the area of failure.
Mar 13, 2021 at 3:30 AM
RANDY CARTER
Thanks Roy. Torque converter/brake switch B circuit high P0724 Changed brake peddle switch. Lost comm with ebcm U1041. Class2 data link malfunction U1000, Pump motor circuit open C0267 and C0265, EBCM module C0246,C242, Co251 and Co252
Got it. Looks like the ABS module is the failure
Bulletin
Bulletin No.: 04-05-25-002
Date: March 10, 2004
TECHNICAL
Subject:
ABS Light On, DTCs C0265, C0201, U1041 Set and/or Loss of Communication with Brake Module (Reground G110 ABS Ground)
Models:
2004 Buick Rainier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche, TrailBlazer, TrailBlazer EXT
2003-2004 Chevrolet SSR
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon Denali, Yukon XL
2002-2004 GMC Envoy, Envoy XL, Sierra Denali
2004 GMC Envoy XUV
2002-2004 Oldsmobile Bravada
Condition
Some customers may comment that the ABS light is on. Upon further inspection, DTCs C0265 and C0201 may be set in the brake module. It is also possible for DTC U1041 to set in other modules. There may also be a loss of communication with the brake module.
Cause
A poor connection at the G110 ABS ground is causing unnecessary replacements of brake modules.
Correction
DO NOT REPLACE THE BRAKE MODULE.
Perform the following steps to improve the connection of the G110 ground:
1. Remove the G110 ground. The G110 ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the G110 ground can be identified as the heavy (12-gauge) wire.
2. Clean the area, front and back, using a Whiz Wheel(R).
3. Install the bolt, ground and a star washer to the frame.
4. Install a star washer and nut to the backside of the frame.
Tighten
Tighten the nut to 9 N.m (79 lb in).
5. Cover the front and backside of the repair area using Rubberized Undercoating.
Other codes
Circuit Description
The ABS relay supplies battery voltage to six valve solenoids. The EBCM microprocessor applies the grounds needed to activate each solenoid. The low side of each solenoid coil has a feedback circuit to the EBCM microprocessor. When a solenoid is commanded OFF, the feedback voltage is high. When a solenoid is commanded ON, the feedback voltage is low.
Conditions for Running the DTC
-The ignition is ON.
-The vehicle speed is greater than 6 km/h (4 mph).
Conditions for Setting the DTC
The EBCM detects an internal malfunction.
Action Taken When the DTC Sets
C0246, C0251, C0252, C0253 and C0254
If equipped, the following actions occur:
-The EBCM disables the DRP/ABS.
-The ABS indicator turns ON.
-The red brake warning indicator turns ON.
C0247 and C0248
-The EBCM disables the ABS.
Conditions for Clearing the DTC
The Conditions for Setting the DTC are no longer present and you use the scan tool Clear DTC's function.
Diagnostic Aids
An intermittent open/shorted solenoid DTC can be set by several different internal EBCM problems. Replace the EBCM if an open/shorted solenoid DTC continues to set intermittently.
RANDY CARTER
Yep the module has bad I found this video to help me change it out.
https://youtu.be/lUotkKXG9dY
all fixed
