Will not start
260,000 MILES • 2.4L • 6 CYL • 2WD • MANUAL
  • 110,251 POSTS
Have a helper turn the key to the start positing while you check for power to the smaller wire on the starter. You should have twelve volts. If you do, chances are the starter is bad.
Aug 2, 2017 at 4:38 AM (Merged)
CYNDA
Car starts, when I try to push accept on MMI, nothing happens, screen stays the same. No access to CD etc. What is wrong? I cannot afford the dealer. please help.
  • 31,937 POSTS
You may need to get the system re flashed, this will have to be done at a dealer as this will be an in house system. There may be a module failure or a touch screen failure but unfortunately these will have to be checked out by a dealer as i doubt that any independent work shop will have the soft ware to do this.
CYNDA
Thank you for your help! I will take it to the dealer.
  • 31,937 POSTS
okay, please post what you find as it may help others.
CYNDA
Okay, I will. :)
