A/C suction line leak
1997 FORD EXPLORER
100,000 MILES • 4.0L • 4 CYL
CASHJACK
  • 18 POSTS
Bought new suction line for A/C. New hose had three o-rings where as old hose had two o-rings. The metal pipe diameter was the same size. Condenser fitting was same size. Napa store guy stated this was a direct fit. Pulled vacuum, leaked test, and found leak at the o-ring connection. Do I use thicker o-rings?
Jun 4, 2018 at 6:36 AM
Good evening.
No, remove the fitting again and inspect the o-rings and see if they got damaged from the installation. If one rolled over or got cut, this will result.
Did you lube the o-rings before you installed the line?
Jun 4, 2018 at 9:21 AM
