A/C leak
205,500 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JOSHUA WRIGHT
I charged the A/C and a couple weeks later the Freon discharged out of the air conditioner and now it isn't working.
Jul 3, 2019 at 5:52 PM
Good morning,
It sounds like you have a leak which can be hard to find but using this video and guide will help.
https://youtu.be/yrhWKlQEPWw
and
https://www.2carpros.com/articles/air-conditioner-leak-detection
Let us know what happens and please upload pictures or videos of the problem.
You need to add some leak dye to the system and use a good bright LED light to determine the leak.
The condenser is a common area of leaking.
Whatever you do, do not use a sealer in the Freon system. I will cause damage to the system and will not work correctly.
A/C Condenser Core
The A/C condenser core is located in front of the radiator. The A/C condenser core receives compressed (therefore heated) refrigerant gas from the compressor.
As the hot refrigerant gas flows through the A/C condenser core, it is cooled by air passing over the fins. The cooled, compressed refrigerant gas condenses to liquid refrigerant which flows directly to the A/C evaporator core through the A/C evaporator core orifice in the inlet.
Jul 4, 2019 at 12:28 AM
