A/C compressor clutch fan cycling quickly
109,000 MILES • 3.3L • V6 • FWD • AUTOMATIC
EWPFAFFLY
A/C is not cold. I tried to put in R-134a refrigerant. I connected can of refrigerant to the low pressure side of system. I was using the supplied gauge. Car was running. I turned on the A/C from inside, set fan to high, made sure it was not on recycled air, the diagram showed air coming from A/C vents in vehicle. At first the pressure gauge was at zero, and the compressors clutch was not moving. I added a little R-134a and the pressure gauge went up to 45 psi. It didn't take hardly any R-134a to make it go up to that. At that time the clutch started kicking in and the pressure gauge went to zero. Then the clutch disengaged it went back up to 45 psi again. The clutch fan would run for about five seconds, then shut off, then after five to ten more seconds come back on. It keeps repeating this cycle. The low pressure side never did get cold and the high pressure side never got really hot. I have read about using the gauges that come with the refrigerant but I had no other gauge to use. There is an access port on high pressure side and when I took off the cover there is just what looks like a tiny round window which is showing a black color. I have read about the relays and such but did not want to spend money to trouble shoot. I did check the clutch relay under the hood and switched it with another one, which was the exact same kind. (The part number was the same.) Still no luck. I have not checked the low and high pressure relays that connect to the A/C lines under the hood. Any advice is welcome, thank you.
Aug 11, 2017 at 7:59 AM
CARADIODOC
  • 34,415 POSTS
Forget all the electrical tests. By your own observations, everything is working. It sounds like the system is just really low on charge.
Before we go any further, you are fortunate that Chrysler is the only manufacturer that used a sight glass that was accurate, to tell when the system is fully-charged. Adding too much refrigerant is potentially more harmful that having too little, so when full is good, more is not better. Loosen the jack and handle under the hood, then you will see the round receiver-drier on the inner fender. There is a 1/4"-diameter round sight glass right in the middle of that. Fill the system just until you no longer see vapor bubbles flowing through there.
When the compressor cycles off, the high and low sides will want to equalize. That is where you are seeing the 45 pounds come from. When the compressor turns on, it is pumping the low side down too low. You do not want to see it go much below 40 psi. There is a low-pressure cut-out switch that turns the compressor relay off when low-side pressure gets too low. Refrigerant has a nice coincidence that its pressure is nearly identical to its temperature, (when the system is at rest). The low side is regulated to not go below about 40 psi because that means the evaporator in the dash is at 40 degrees. The goal of any AC system is to lower the air temperature by only 20 degrees. The comfort comes from condensing out the humidity. That moisture collects on the evaporator just like it does on the side of a carton of cold milk. If the evaporator were to get down to 32 degrees or lower, that water would freeze into a block of ice that would block air flow.
That is the regulating part of the story. The low-pressure cut-out switch part of the story has to do with a leak in the system. If the refrigerant is lost and the compressor was able to run, it could draw in outside air and the humidity in it. Moisture and refrigerant combine to form an acid that will attack metal parts in the system. Also, if a drop of moisture was circulating in the system, it would freeze at the expansion valve and block the flow of the refrigerant. The typical symptom is it cools fine for a few minutes, then you get only warm air for about an hour, until that ice melts.
Any time the system is that low, we repair the leak, then pump it into a vacuum for at least half an hour. In a vacuum, water boils at 77 degrees. That turns it into a vapor that is easy to pump out. That vacuum also aids in starting to put some refrigerant into the system.
If you started with 0 psi in the system, the compressor will not be running, and it will be hard to get the refrigerant to go in. To be that low, there is likely a leak that needs to be located and repaired first, then you need to pump it into a vacuum. If there was some pressure yet, you need to get enough refrigerant in to get the low-pressure cut-off switch turned on. If that is the only issue, moisture is not a concern. To make the compressor stay on, unplug the low-pressure cut-off switch, then jump the two terminals in the plug. I use a stretched-out cotter pin or paper clip. The compressor will draw the low side down well below the pressure in the little can. You will feel the can get real cold when the refrigerant is going in.
Be sure to always keep the can upright. That makes the refrigerant boil and go in as a harmless vapor. If you hold the can upside down, liquid will go in, and with the charging port so close to the compressor, that liquid can lock up the compressor and damage it. That is also what an over-charged system can do.
Watch the sight glass. Foam is a sign the system is real low on charge. You will see fewer and fewer bubbles as the system becomes fully-charged. If it takes more than ten to fifteen minutes and the can still feels heavy, try setting it in a pot of hot water. That can make everything go in within less than a minute. When you approach a full charge, you will see the gauge on the charging hose stay above 35 to 40 pounds.
Be aware too that those charging ports always leak. The purpose of the valves in them is to hold the refrigerant in to give you time to screw on the caps. Those caps have rubber seals in them, and that is what does the sealing. Do not leave a cap off when you are done.
I should mention too that refrigerant is extremely dangerous to work with. It can cause frost bite and blindness. Professionals wear gloves, safety glasses, and a face shield.
Aug 12, 2017 at 2:38 PM
EWPFAFFLY
You are a lifesaver. When I jumped the clutch relay it engaged the clutch and it started sucking in the refrigerant. Got it up to 45 psi. and now it is blowing really cold. I appreciate your advice.
Aug 14, 2017 at 1:43 AM
CARADIODOC
  • 34,415 POSTS
Come back to see me with your next problem. I have four Grand Caravans including a '94 and a '95.
Aug 14, 2017 at 11:01 AM
EWPFAFFLY
Okay. I do have one more issue. After starting it first time everything worked. Then second time gauges didn't work, the power locks wouldn't lock the door. Unlocked was fine. Then 3rd time check gauges and other idiot lights stayed on after starting but flickered when I messed with gear shifting but they didn't go away. A couple of times when starting it gauges would start to move but then stopped moving and went back to zero. Lastly after starting it the radio stopped working, on top of the other issues. I even unplugged negative wire to battery for 10 min, then reconnected trying to see if it would reset but that didn't make a difference All fuses are good as are the relays under the hood. I did do some researched which indicated it is probably the body control module under the dash, which is a little difficult to get out, it's on top the fuse box I think. I wanted to take it out so I could visually make sure the one I bought is the same exact one that is in there now. New they want $237.00, I found used one on ebay for $80.00. But I haven't bought it yet because I need to see that it is the right one. What are your thoughts? Any advice is greatly appreciated.
Aug 15, 2017 at 1:03 AM
CARADIODOC
  • 34,415 POSTS
This sounds like an ignition switch problem. When the radio quits, the heater fan and power windows will quit too because they're all on the same circuit. The clue is that circuit will work again after turning the ignition switch off, then back on.
There's three T15 Torx screws under the steering column cover to remove. Two hold the top half to the bottom half, and one holds the bottom to the column. The long flat connector is at the bottom of the switch assembly. Unplug that, then check the terminals to see if two are darkened. If this gets really bad, the connector body will melt in that area.
If you find those two darkened terminals, the switch and those two terminals must be replaced. High resistance between the switch contacts or between the mating terminals causes heat build-up, and that heat causes more resistance. The heat from either one migrates to the other one, so the switch contacts AND the terminals must be replaced. It's a vicious circle, and that is aggravated when the heater fan is used on the higher speeds a lot and when the ignition switch is switched off or on when the heater fan switch is on a higher speed. The fan draws a real lot of current and that causes arcing across the switch contacts that adds to this problem.
An additional potential clue is if you have a cassette radio and power windows, the cassette player will kick out momentarily when you run both power windows down and they bottom out at the same time. The cassette will engage again when the window switches are released. Any motor draws higher current when it locks up. That higher current causes more voltage to be dropped across the burned switch contacts. That results in less voltage feeding the circuit. The radio sees the lower voltage and incorrectly interprets that as the ignition switch was turned off. It disengages the cassette pinch roller so it doesn't develop a flat spot.
If you find the ignition switch needs to be replaced, I'll describe how I handle the terminals and the wires.
Aug 15, 2017 at 8:52 AM
