A/C Compressor relay location
CARADIODOC
  • 33,916 POSTS
Once the fuel pump is running on a Chrysler product, it is extremely rare for them to cause a problem while driving. By just throwing more and more parts at it, you're adding more variables and potential problems. This will make it very hard to diagnose the original problem.
It is almost unheard of to fix a running problem on a Chrysler product by replacing the fuel filter. It is more likely you'll find a plugged pickup screen in the tank, but the symptom will be the engine dies when the largest volume of fuel is being pumped, which is during coasting at highway speeds. Less fuel is moved during acceleration so it's easier to maintain the necessary pressure.
The "rings" for the spark plugs are gaskets. Although unlikely, pull a spark plug back out and check the gap. Without the gasket in place, the plug could have been screwed in too far, and the piston might have hit the electrode closing the gap. Since the no-start problem first occurred after replacing the plugs, wouldn't it make sense to put the old plugs back in? At the very least, physically compare a new plug to an old one.
As for sluggish running, my first guess would be a MAP sensor, particularly since throttle position had an effect on the symptom. Now that it doesn't start at all, I would suspect a defective camshaft position sensor or crankshaft position sensor. Normally, either of these sensors will set a diagnostic fault code and turn on the "Check Engine" light. Retrieving the fault code will tell you which sensor is causing the problem. It is possible for the MAP sensor to report incorrect values that result in poor performance, but as long as the incorrect values fall within the acceptable range, a fault code will not be set in memory. Eventually, the sensor will fail completely; then a fault code will be set, and the Check Engine light will turn on.
Caradiodoc
Monday, July 27th, 2020 AT 1:15 PM (Merged)
PETER FABULIAN
  • 6 POSTS
  • 1999 DODGE CARAVAN
  • 3.8L
  • 6 CYL
  • 248,000 MILES
AC needs to be charged almost every summer. Still no AC when I started the AC, and there was no activity on the compressor if I jumped pin 30 to pin 87 on the AC relay. I put in approximately 60 plus pounds of r134 in and now the compressor clicks and moves but does not engage. What should I try next? Please advise.
  • 52,797 POSTS
Good morning.
When you say the clutch clicks and does not engage, do you mean the compressor clutch is not turning?
PETER FABULIAN
  • 6 POSTS
Yes, it clicks but does not turn. Before I added the R134 it did not even click.
PETER FABULIAN
  • 6 POSTS
Yes Roy, the compressor does not turn.
PETER FABULIAN
  • 6 POSTS
Also, the clutch pulley spins freely with engine off.
  • 52,797 POSTS
Okay, if you have current at the compressor, then you need a compressor and a receiver dryer for the system.
KPCOUPE
  • 1996 DODGE CARAVAN
  • 6 CYL
  • 196,000 MILES
I just replaced the compressor the evaporator and the drier on my van I vacuumed down the system and added 24 oz. Of 134a the head preassure was getting to high I relized the condensor fan was not coming on so I checked all fuses and replaced the relay the fan started working so I added a third can of 134a so the air works good until the fan decides it does not want to come on. I have checked the fans and replaced the relay. Now I cant figure out what else it could be. I have also checked the wires for bare wires and found nothing. The other day at a stop the compressor started blowing off threw the presure valve. Then when I started moving it did fine.
Could it be in the high pressure line switch? Or what else can I check
DOCFIXIT
  • 18,828 POSTS
In order to help you need to know low side and high side readings at idle windows open fan on high. Also did you add oil?
PETER FABULIAN
  • 6 POSTS
Thanks much for your prompt response.
  • 52,797 POSTS
You are welcome. Feel free to ask any follow up questions.
