A/C clutch not engaging and belt not spinning
200,700 MILES • 6.4L • V8 • TURBO • 4WD • AUTOMATIC
ABCDEFGH0987
Clutch will not engage. I’m extremely low on Freon and suspect that’s the cause. Until today the belt and pulley would still spin with the A/C on. Now it’ll only spin when A/C is off. The pulley and clutch can spin by hand. Not sure what would cause the pulley to do this.
Aug 10, 2019 at 1:34 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Low Freon levels will prevent the compressor from engaging. However, I'm not sure I understand what is now happening. Do you mean when the AC is on, the pulley stops turning as well as the belt?
Here are a few links you may find helpful. However, let me know exactly what is happening at this time.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Aug 10, 2019 at 1:28 PM
