Airconditioner blows Hot for first 20 minutes
69,000 MILES • 6.7L • V8 • 4WD • AUTOMATIC
GDK1977
Airconditioner blows hot air for 20 min after starting, but only when the outside air is warmer than 85 degrees. It blows cold air in the mornings right away, but if I start the truck in the PM, it blows hot for approx 20 min. then it starts blowing cold air.
Apr 18, 2017 at 11:39 PM
HMAC300
  • 48,601 POSTS
try resetting actuators by pulling fuse 50 under h ood for 60 seconds with key on then reinstalling.. I am assuming compressor is kicking on and large pipe under hood is cold with in a few minutes. then it will have to be scanned for codes by a mechanic . If this is auto temp control where you set the temp inside car then it will have to be scanned for codes as a sensor may be bad causing it. you can also check fuses in body module if you can see any and try fuse 48 it's under right kick panel. but those may be internal
Apr 18, 2017 at 11:58 PM
GDK1977
Nope, i checked both those fuses and pulled the first out foe 60 sec. and no improvement I will take it to autozone for code.
Apr 20, 2017 at 8:50 AM
HMAC300
  • 48,601 POSTS
autozone will not be able to read the codes on hvac they can only read engine/trans codes some abs codes a mechanic has to use his scanner to read it.
Apr 20, 2017 at 9:08 AM
