A/C charge
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
FATALK0
Replaced my expansion valve. will I need to pull vacuum in order to refill my Freon?
Jul 26, 2019 at 3:08 AM
Yes. Anytime you open the system or do any work on it for that matter, you want to pull a vacuum for two reasons. First, it ensures you don't have any leaks if it holds a vacuum for at least 15 minutes. Second, it pulls the moisture out of the system which is damaging to the compressor and other components.
Here is a guide that will help. Let me know if you need more information. Thanks.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 26, 2019 at 7:54 AM
