Speedometer fluctuates after driving 35 MPH?
RAILFANNER
  • 16 POSTS
Oh, I also bought a second set of speed sensors recently, as they were inexpensive, and I thought maybe that would help, or if the alternator were originally bad, that could have hurt the first set of sensors I put in. But I have NOT put these in yet. I am concerned that something else electrical could harm the sensors. I don't want to install these and have them get zapped if that is possible.
Sunday, February 12th, 2023 AT 7:55 PM
  • 109,885 POSTS
I just sent him a message regarding this. He usually will check within a day, so hang in there. Also, I don't think the alternator is the issue. Nothing changed with all the things you've done. If there would have been a variation from what it's doing, then I may question it. You basically have replaced everything.
Let's see his response.
Sunday, February 12th, 2023 AT 7:58 PM
RAILFANNER
  • 16 POSTS
Sounds good. And no real hurry - ha. I have endured this for a year, and after reading everything I can on this issue, I have not seen a reliable fix by anyone, ever. So, it's a holy grail type of issue - when solved, it will be a big deal. Or at least for a lot of folks still driving these relics.
BTW, haven't replaced the battery, as discussed, that battery is getting pretty old, but still starts reliably. Long while back, had a bad relay (now replaced) that was causing parasitic draw of power that drained battery several times, had to jump-start and recharge batt several times before I found that issue and fix. Maybe that harmed something back then. Oh, and I have checked the ground points in the engine bay. All look clean and beautiful, not crusty, loose or dirty - they look pristine, tight and original as the day the car was built.
I have not taken my car to a Chrysler dealer, as I've just heard too many completely clueless and $$$$ failures on this same issue from those that went that route. But, if there is no other recourse, I may have to try that - someday. But let's see what else may be suggested. Cheers!
Monday, February 13th, 2023 AT 7:33 PM
  • 109,885 POSTS
I had the chance to speak with Ken today. We discussed what you are experiencing, and he had an idea. He suspects there is a faulty diode in the alternator which is allowing an AC signal to interrupt different circuits. In this case, it would be the speedo.
He suggested this. Using a multimeter, set it on AC and check for power at the battery with the engine running. The meter should indicate 0. Have a helper rev the engine a bit to see if the meter indicates anything.
Let me know what you find.
Tuesday, February 14th, 2023 AT 12:44 PM
RAILFANNER
  • 16 POSTS
Interesting. I did see this idea (lots of reading on all possible issues on Internet) and I remember this idea - and it's why I originally changed to a brand-new alternator. But I was not given a simple test like this to try. So, I replaced the (original/old) alternator and put in the new one. And the issue was still there. It's possible but unlikely that the new alternator has a bad diode, unless there is something to cause that! But I'll try to run the AC check and see if there is an AC reading.
2 Questions:
1. The battery is tough to get to, behind the left front fender wheel well. And, I'll have to jack and allow FWD wheels to freewheel under acceleration. So, can I check at the + positive post (recharger point) in the engine bay (and ground) to watch for AC current with car wheels accelerating?
2. Can this check be done while driving the car? Reading any AC from cigarette lighter, or from fuses point in the car?
Just seeing if there is a simpler/safer way.
Tuesday, February 14th, 2023 AT 6:49 PM
RAILFANNER
  • 16 POSTS
Oh duh. You prob mean just put car in neutral and rev the engine, right? No need to allow wheels to spin. Sorry, I just jumped to that. Please confirm.
Tuesday, February 14th, 2023 AT 6:53 PM
  • 109,885 POSTS
Yep. You just need to rev it in neutral. Let me know what you find.
Wednesday, February 15th, 2023 AT 5:46 PM
