1999 Chrysler Sebring won't get out of lower gears - speedm
MTRUDEAU
  • 1999 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 11,700 MILES
My chrylser won't get out of 2nd gear until it reaches about 5000 rpm. Also the speedometer doesn't kick in until about that time. It seems to be missing.
Monday, December 7th, 2009 AT 5:52 AM
CARADIODOC
  • 33,916 POSTS
Try to avoid 5,000 rpm. That will destroy most engines eventually. The dead speedometer is the clue that the input speed sensor or the output speed sensor are intermittently not working. That is a relatively inexpensive repair, but if you keep driving it like that, the sudden engagement when it does start working could do serious damage to the transmission, flex plate, or drive axles.
Second gear is the default it goes to when the transmission computer detects a problem. It's interesting that your transmission will eventually upshift, if I understand you correctly. Normally it will stay in second, neutral, reverse, or park until the ignition switch is cycled off and the engine is restarted.
Caradiodoc
Tuesday, December 15th, 2009 AT 2:18 AM
