Put the new used BCM and relearned the pass-lock but still no start and no fuel gauge no tachometer movement also. And scanner wont connect. Crankshaft position sensor? It was changed in 2012.
Sunday, January 26th, 2020 AT 2:54 PM
JUGGALO45
MEMBER
I'm going to have it towed home soon. Ugh. Frustrating. And it shifted hard out of park and kinda funny while driving and it was all highway 55 mph.
Sunday, January 26th, 2020 AT 2:56 PM
CARADIODOC
MECHANIC
Could both BCM's have broken solder connections? Did you re-solder them on either computer? It sure sounds like everything else is working in those circuits, other than the BCM.
Sunday, January 26th, 2020 AT 3:00 PM
JUGGALO45
MEMBER
No I should of and going to now when I get her back here. I will keep posting my so call progress. Thanks
Sunday, January 26th, 2020 AT 3:02 PM
JUGGALO45
MEMBER
I'm at a total loss. Even change crankshaft sensor so I can scratch that off the list. Forgot to grab the BCM to solder it. Car still not at home. Going to get it towed home or thinking maybe to dealership and bite it. Hate to do that though.
Monday, January 27th, 2020 AT 2:45 PM
JUGGALO45
MEMBER
I'm going to start over and check grounds. Something's just not right.
Tuesday, January 28th, 2020 AT 3:25 AM
JUGGALO45
MEMBER
Thanks guys you did help a lot. It was my fault. After I took a couple days off from it I went back started over. It end up being that I purchased a faulty main relay from the store after finding the same relay. I swap it out and I got power to my ECM am I fuel gauge came on. I did a relearn on a BCM car started right up. Thanks guys you were a great help. I owe you big time but tell you what I learned a lot and I'm going to save this information that you posted. The 2004 Saturn L300 crank but no start problem is solved thanks to 2CarPros. If I knew where you were I'd buy you a drink.
Friday, January 31st, 2020 AT 5:22 PM
CARADIODOC
MECHANIC
Dandy. I'm happy it was so inexpensive even though it took us a while. In the end, you figured it out so give yourself a pat om the back.
Friday, January 31st, 2020 AT 6:28 PM
JUGGALO45
MEMBER
Yes sir, thanks again. Though what was the odds of getting a bad relay new? The whole job was frustrating for something so simple but I knew I had to start over something wasn't right. Thanks a lot guys.
Friday, January 31st, 2020 AT 7:39 PM
KEN L
MASTER CERTIFIED MECHANIC
CARADIODOC is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
