Yellow abs tyre pressure 4+4, and brake warning .
2005 BMW X3
70 MILES • 2.5L • 6 CYL • 4WD • AUTOMATIC
MARK091265
I went over a bump , and 4 yellow lights came on , I've bought a hand held to re sett them , but no good !!,
Mar 7, 2014 at 10:26 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
does the car drive poorly now? will the handheld read the codes? if it drives fine now then you may have just tripped the traction control system momentarily and the handheld may not be able to read that. some only do engine codes
Mar 8, 2014 at 7:13 AM
