Would not start
1998 OPEL VECTRA
4 CYL • 2WD
CHIBUIKE OBETTA
The car wouldn't start but blink check light
Nov 18, 2020 at 3:17 AM
If the engine does not crank then we need to find out if we are getting voltage to the starter.
Here is a guide that will help with no start issues so let's run through this info as well as that may help get us on the right path:
https://youtu.be/dCjmRL3p4Cs
Lastly if the check engine light is blinking when you are cranking the engine then that is usually an issue with the theft system but I don't have a manual on this vehicle as it was not offered in the USA. So I am not able to tell if this vehicle has a theft system or not.
I would suggest starting with checking for codes and going from there.
Please run through this info and let us know if you have other questions. Thanks
May 27, 2021 at 12:10 PM
