Will not start, one and three cylinders have no compression
155,500 MILES • 2.4L • 4 CYL • 2WD • MANUAL
MY88MUSTANG
No compression in one and three cylinders. Will not start. Replaced camshaft sensor, cam sender plugs and wires.
Jun 10, 2018 at 2:52 AM
Good afternoon.
With no compression in two cylinders I would be surprised if it did start. There is a reason for that. It is possible that the timing belt failed and when it did, that failure caused valve damage to the cylinder head.
This will need to be verified.
A shop can do a leak down test to confirm by adding shop air into the cylinder and finding the leak.
https://www.2carpros.com/articles/how-a-timing-belt-works
Jun 10, 2018 at 5:31 AM
